Ich spreche nicht deutsch zu viel, also notiere ich mein Problem auf englisch, sorry Ich wünsche hydrolic Steuerung für mein '90 Corsa A. irgendwelche Ideen?
I have just started the project. I am restoring my old car which is 1990 Opel Corsa A 1.4 CC.
It is a C20LET project.
I want to learn that what I have to do for hydrolic steering for Corsa A.
If I change the parts with Corsa B, it is OK ?
Any Ideas??
Respekt,
blackybeth...
hydrolic Steuerung
Re: hydrolic Steuerung
HI,
Yes you can try the parts of Corsa B or you can look for parts of Kadett e 1.6i with hydrolic steering.
Signatur? Was isch das denn
Corsa1986 hat geschrieben:HI,
Oh I've seen you have a c20let, so you will be only able to use the electric steering of the Corsa B, becaus of de The Riemenscheibe
so, What can we do about that c20let... I want to hydrolics with c20let. opel calibras are OK ?
I think he means that the problem is the C20LET engine togehter with hydraulic steering.
You just won't have enough room left for the pump and the belt.
Maybe you can solve this problem by using an electric pump for the hydraulic steering from an Astra (98-04)
The steering gear can be used from the Corsa B (93-00) with shortened steering links.
