Sportfahrwerk 60/40mm
blackybeth
Beitrag von blackybeth »
hallo, mein Deutsch ist nicht gut. So I write it in english :)
I want to use Billstein B10 for my Corsa A. It has a 60/40mm lowering springs on it.
Ich möchte Billstein B10 für mein Corsa A. Es hat 60/40mm senkenfrühlinge auf ihm.
I am going to use 16" mille miglia spider with 215/40/16
Ich werde verwenden 16"; mille miglia Spider mit 215/40/16
My question is billstein b10 is good for Corsa A. Any suggestion ?
Meine Frage ist billstein b10 ist gut für Corsa A. Irgendein Vorschlag?
60/40mm lowering kit is a problem with the 16". is that going to fit or need modification in wheelhouse...
60/40mm der senkeninstallationssatz ist ein Problem mit dem 16". Notwendigkeitsänderung im Ruderhaus…
Re: Sportfahrwerk 60/40mm
Beitrag von Schneefuchs »
First U have to look, how much the Wheels are standing outside from the carbody, even the front and also the rear wheel. The bigger problem is not to lower the car, but the Wheels with the tyres. You have to make the Wheelhouse wider, so that the tyres are covered, even if the car is loading a heavy weight, so that no Tyre is touching the wheelhouse.
It belongs to depth of the Wheels, how far they come out, if they are mounted...
Hopefully i could help you...
blackybeth
yes, absolutely... I understand what you mean. I have a picture with the same rims on Corsa A. it seems no modification on front and rear. I just worried about 60/40mm springs.
What do you think about the billstein B10 ?? different suggestion ?
I don't know, I have a very cheap 40/40 mm. But i think there are some People here who have experiences with Bilstein.
