Hello
Sorry for writing in English but i'm Portuguese and it's a little easy for me. I would like to know if a Mattig Fächerkrummer with the code KAT2004-7 can be fitted in C14SE engine of a Corsa A. I'm asking this because i found here in the forum the TUV Certificate and it has other codes but i can't translate it very well and i can't understand if it can be fitted or not. KAT2004-7 i think that is referenced to c12nz, c14nz, e16nz.
Here it is the certificate:
http://mitglied.lycos.de/jandittrich/fa ... echer1.JPG
http://mitglied.lycos.de/jandittrich/fa ... echer2.JPG
Please help me.
Thanks a Lot
C14SE Fächerkrümmer
Re: C14SE Fächerkrümmer
which type you have ?
if you have typ "M" it will fit, because "M" is "Corsa A cc with C14se engine" .
i hope i`am right
i hope i`am right
Thanks a Lot for your answer. The type that i'm planning to buy is the L one - KAT2004-7, it also has the Lambda Sensor socket, so what would be the diferences?
Thanks a Lot
Thanks a Lot
The difference between the Astra version and the Corsa version of the "Mattig Fächerkrümmer" is probably the length of the "rear end" / the length of the connection to the catalytic converter.
If you have a Astra Version you can use the "Fächerkrümmer" anyway by welding a flexible connection piece between the Fächerkrümmer and the pipe coming from the catalytic converter.
But maybe you will have to cut a part of the Fächerkrümmer.
Ok...Thanks Everyone for your answers. I talked to the guy that is selling the Fächerkrümmer and he said that it was installed in a Corsa A C12NZ so it will fit the C14SE without no problems. Probably i will only need what Black13i said.
Thanks
Thanks
