alu tankdeckel
c20rsa
alu tankdeckel
Beitrag von c20rsa »
Hi!
I m wondering how to put alu tankdeckel behind the doors, like Bart did. I ve seen it in the gallery.
which tankdeckel is it? is it from a motorcycle?
Timme
Beitrag von Timme »
Hi
It's probably the best to take one from a motorcycle, but you have to weld the whole part around of it to this place aswell! So at least you have to buy the complete tank and put out this part where the "tankdeckel" is! then you have to get the tube to this point where you want to get your "tankdeckel" in!! Then clean the old point with a sheet!!
BUT be carefull, because of the vapours from the gas-tank!
I hope you understand me! :wink:
So have fun and greetings to Croatia!!
Timmy 8)
c20rsa
thanks, i understand almost everything...
can you just tell me from which motorcycle it is?
Timme
Beitrag von Timme »
I think it's no specific! You should take one from a Suzuki GSX/R or things like this! :wink:
c20rsa
thanks, and one more question...
Is this Bart, registered here...or how can I reach him?
Timme
Beitrag von Timme »
No Problem!
To your question: contact Beany! He's the Admin here and I think he can tell you this! because I'm not sure if Bart is regristrated here!
c20rsa
thanks... :wink:
